AE  B6.2D / B6.2 Thread >
Like Tree1409Likes
    Hide Wikipost
Old 10-30-2020, 02:57 PM   -   Wikipost
R/C Tech ForumsThread Wiki: AE B6.2D / B6.2 Thread
Last edit by: Kraig
Reference Guides (courtesy of Ray Munday and Roger M.): What is the difference between 2 gears and 4 gears in the gear diff?
Please read these posts by Roger M. Maybe this has been answered but what are the little orings in diff do for tuning?
Information on the rear axles and the different length dog bones from Roger M.
The 0 (option) and +2 (kit) axles are for using different length driveshafts with the different arm lengths
Kit +2 axles
73mm arms wih 67mm driveshafts
75mm arms with 69mm driveshafts
Option 0 axles
73mm arms with 65mm driveshafts
75mm arms with 67mm driveshafts
Why would you want to change the driveshaft length?
It is essentially to do with the fact that a drive joint will want to run straight under power and the position of that joint (the pin through the CVA joint into the axle).
The further that CVA joint pin is inboard of the lower hub hingepin (assuming you're running fairly typical outer link positions) the more bind you will generate in the suspension as the drive joint tried to straighten under power, this extra binding will 'stiffen' the suspension as it adds load on top of that from the weight transfer on the car.
Conversely the the nearer the CVA joint pin is to lower hub hinge pin the less bind and thus freer suspension movement.
When would you want to change this?
Basically on bumpy tracks, tracks with inconsistent grip or lower grip you want the suspension to be as free to move as possible so that you get the full benefit from the shock and roll centre tuning, also the car feels like it has more grip in the areas where you go on/off/on the gas.
To this end you will be running the longest possible dog bone you can for the arm length, hence why the +2 axles are in the kit.
On smooth super high grip tracks (EOS / CRC carpet for example) running a shorter dogbone will feel like it takes grip away from the rear as you get on power, aiding late corner rotation and reducing the on-power understeer that often plagues tight carpet tracks.
The only time I would run the 0 axles is with 67mm dogbones on 75mm arms and only then when I wish I could get let rear toe than the 1deg minimum we can get from the pills we have (actually I had custom pill made so I can get 0deg rear toe for those types of tracks but ...)
What are the handling differences between the 73 and 75mm arms.
Brief explanation from RogerM (thanks!)
The arm length effects the roll centre and more significantly the roll centre migration as the car rolls in the corners.
Shorter rear arms will encourage more tire loading so more grip as the car rolls, great for lower grip surfaces but on high grip surfaces they can stall the rotation mid corner costing corner speed. They can also make the car feel more reactive which is good when a low grip level makes the car feel less reactive so making it harder to place in technical sections.
Long rear arms the opposite, car will rotate more freely for more corner speed but won't generate as much side-bite so mid/late corner will be reduced. Make the car feel naturally lazier which is great on high grip surfaces as it makes the car easier to drive overall.
So the long Vs short rear arm is just like the flat Vs gullwing front arm, all about the grip level from the surface and how technical the track layout is.
Print Wikipost
Old 01-08-2020, 05:10 PM
Trader Rating: 43 (100%+)
Default AE B6.2D / B6.2 Thread
New kit 1/8/2020
Ch47guru and Teknewbee like this.
Phillip F is offline
Old 01-08-2020, 06:17 PM
I am ready for a new buggy!
who will have them first?
Idriveayellowr is offline
Old 01-08-2020, 06:41 PM
I'm just happy AE is coming up with a buggy that is dedicated to outdoor wet dirt tracks. (old school tracks/real off road)
BUT, we will see how it performs. I race at Hot Rod Hobbies where the SHOOTOUT race and JBRL racing series happens.
I race the B74 at Hot Rod and the buggy has been amazing at the track.
Hopefully this new "dirt" 2wd performs so much better than the B6.1D and the B6.1 (converted to dirt setup).
francomang likes this.
Old 01-08-2020, 07:20 PM
FYI there is a first-come-first-serve fast track email waiting list on the Team Associated page for each vehicle.
https://www.associatedelectrics.com/...C10B6.2D/Team/
https://www.associatedelectrics.com/...RC10B6.2/Team/
mushroomed is offline
Old 01-08-2020, 07:31 PM
Davidka's Avatar
Trader Rating: 86 (100%+)
This doesn’t appear to be for different conditions than the 6.1d. It’s a fairly minor update.
SCRAFAN and Big_Show like this.
Davidka is offline
Old 01-08-2020, 08:40 PM
dickie doyle's Avatar
Trader Rating: 17 (100%+)
Mid mount for shocks?
dickie doyle is offline
Old 01-08-2020, 08:41 PM
Originally Posted by dickie doyle
Am I trippin’ or do these look like droop screws?
Those screw the tranny top to the bottom for the easy access diff like the b6.1 did
Kelseyrc is offline
Old 01-08-2020, 08:44 PM
yup, just edited post because I realized that, thanks!
Antimullet likes this.
Old 01-08-2020, 08:46 PM
We will see if all that updates translates at the track. I raced a B6.1 setup for dirt and had good results with it.
Old 01-08-2020, 09:33 PM
lexusbest's Avatar
The B6.2D makes me think about a thing.
this car keeps 67mm bones and 7mm hexes which means that the rear width did not change. So, current arms must be 73mm long too. Then, this car only gets updated hubs for what?
lexusbest is offline
Old 01-08-2020, 09:42 PM
Trader Rating: 105 (100%+)
not if they narrowed (or widened) the chassis where the rear arms mount.
TimF is offline
Old 01-08-2020, 09:43 PM
and the width of the rear hub carriers might have changed
TimF is offline
Old 01-09-2020, 12:29 AM
Default just bought b6.1. It's sad
daiji is offline
Old 01-09-2020, 12:43 AM
lexusbest's Avatar
depends on the track layout you may benefit from the b6.1
Old 01-09-2020, 01:12 AM
wstuart's Avatar
Trader Rating: 117 (98%+)
Looks like the b6.2 gets the new +3mm chassis. I do not see it listed as a feature on the b6.2d. I wonder if the b6.2d chassis is the same as the b6.1?
Do you guys think I could throw the pucks from my b6.1d into this car?
wstuart is offline
